Where can i find the indicator relay on a Piaggio NRG? Just that my dash lights wont work then they will flicker on every few minutes. Every light still works apart from my indicators. Rear and front.
My zip ended up doing this turns out the flasher unit is built into the Recitifier, can't say its the same on yours but if your struggling to find a relay like I was it could very well be built into it. Check wiring diagrams in a Haynes first, they do one which covers a few diffrent scoots in one book, this is the one I've got and I'm sure it covers the NRG >> http://www.ebay.co.uk/itm/Piaggio-T...es_Manuals_Litterature_ET&hash=item35c1421bcf
on my old runner 4t was built into the ignition control unit, i had same problem as you so instead of replacing an expensive part i used a universal flasher unit from another bike and just wired it into the loom
^^Above is a good idea, I got my replacement rec quite cheap, but flasher units is another way to do it
