Dim Lights
Discussion in 'General Scooter Discussion' started by Nubsey, Mar 19, 2021.
  1. Nubsey
    Nubsey Member
    Honda sky 50.
    Back to the Jonway Madness. The lights all work, but are not very bright. Do get a little brighter when revved up but still not brilliant, if you excuse the pun. Any ideas. I hope it's not the alternator.
    Nubsey
  2. MARSH
    What wattage is the headlight bulb ?
  3. Nubsey
    Nubsey Member
    Honda sky 50.
    I don't think that is the problem, because even with the headlights off, they are still not that bright. Any idea how to test the alternator. Also now it's dark I can see that when you rev the bike the lights seem to go even dimmer.
  4. MARSH
    Check voltage out put to regulator (A/C voltage) battery should be getting 14.5 volts D/C if it's charging ok.
  5. Nubsey
    Nubsey Member
    Honda sky 50.
    I have checked the voltage coming from the stator. All looks good, 20 to 70 volts depending on the revs. So I have ordered a new regulator, as it's only £2.39 delivered will try it out. If not possibly some duff wiring to the regulator, as I don't seem to get any voltage, but for £2.39 I will try that first. Also it does not seem to be charging, as voltage increase is next to nothing when engine is running.
