Cylinder help.
Discussion in 'General Scooter Discussion' started by Lope69, Feb 5, 2010.
  1. Lope69
    Lope69 New Member
    what about the intake manifold and reed valves/blocks are they necessary?
  2. MiNoR cOnFuSiOn
    block is only needed f its abigger version than the one your using... otherwisestock locks wht aftermarketreds will do (reeds usually come wiht a 70 kit) th inlet is usually needd for a bigger carb as they dont fit inasmal inlety obviously) and you get dferent length and angle inlets.. usually for fitment problems/all out power application.
    fiters come in messured mouts.. messure your carb and order the right size filter.. stage 6 do a filter in every size forevery carb. as do most filter manufactors.... whoevertld you "it dont fit" has obviously go one andthinks there all the same size.. obviously not as again you can order them in any size prittymuch.
    fact is you dont wanna run a filter... its not even march yet so we have a rainy spring.. filters dont work in the rain hence its no longer a "filter" they filter diret but dont filter water.. this will kill your engine real quick. plus open filters are fuck all use on such small engines. the box will feed more than enough air for the carb. the point of the box is to raise the pressure through the carb = better fueling... plus there weatherproof... ye max power mag's go on and on about more air more fuel, but the fact is your engine will suck the air it needs... your not gonna be building the klind of engine that an airbox restricts... so stick wiht the airbox and forget the chavtunning methods.
    lastly.. there are explinations of ALL parts aswell as usage and even dyno runs on most of the euro sites... no need to ask every question about every part on your bike.. most scooter tunning is down to personal preferance.. build what you want wiht the parts you want... its the only real way of learning/putting your name against it. take advice when given, but dont think you have to ask peoples opinion of everything you buy. its tunning, try it and see for yourself. anyone wiht half a clue about it wont tell you jack shit about getting power out of an enigne its 2 stroke tunning, verry secrative circles) its only because im a mug and have chose to help rather than charge the last 5 years ive been sat here...soon change tho.. my time is no gonna be free for long, just like every other tuner out there...
  3. Lope69
    Lope69 New Member
    thnx minor that really helped alot;)
    finnaly got my bike today, so i hve ordered some of the stuff, but just one last thing, when i buy a new cylinder, does it bring reed valves? i was told today that they do and now once again it has left me :hmm: :eh: :banghead:
    thnx ;)
  4. MiNoR cOnFuSiOn
    you usually get reed petals not a new block... but its essentialy a new block wiht the different petals installed...
    but ye, wait an see i guess....
  5. Lope69
    Lope69 New Member
    i guess ill wait then. thnx again;) :thumbsup:
