Hi there guys. Just bought a honda dylan ses 125 05 plate. Always been a aprillia rider but fancy changing from 2 stroke to 4 stroke so I bought the honda. How do I find out what is the correct spark plug to go in my honda dylan ses 125. Any help would be great Thank you
Thank you That was in the bike allready just wanted to check it was correct can you get a Ngk irridium version Thank again
CR8EHIX-9 although you'll find the 4 stroke will not be so critical as the 2 stroke on plugs and will last much longer even a standard plug.
Sorry to be a pain but our you saying the Ngk irridium CR8EHIX-9 is a good upgrade. And that it would be better for the honda. And when you say it will be less critical do you mean less damage ? Sorry was struggling to understand what you ment. Regards and thank you for the info
2 strokes are harder on plugs compared with 4 strokes so you will find the Honda will go on much longer with a standard plug in comparison. I don't think fitting an iridium plug will make much difference unless the Honda is tuned to a fairly high spec which it probably won't be. The choice is yours. As a former 2 stroke owner you have probably been used to plugs burning out especially if it was tuned but 4 strokes can go on much longer and plugs don't need changing as often. Hope that helps but if you want to fit one it's your choice/money.
