Choosing rear shock absorbers for e-moped
Discussion in 'General Chat' started by Sopheus, May 3, 2020.
  1. Sopheus
    Sopheus New Member
    Hello everyone,
    I need a little advice regarding rear suspension length selection for my e-scooter (Niu U1).
    E-scooter net weight: 56 kg
    E-scooter wheel size: 16X3.0
    My weight: 80 kg (sometimes I ride with my wife, who is about 45 kg)
    Front shock absorber length (I have changed original fork to a longer one): 400 mm
    At the place where I live road condition is not that great, there are a lot of bumps.
    Available rear shock absorber lengths that I'm choosing from (one per each side): 265mm/290mm/315mm
    What would be optimal rear shock absorber length considering the specs above?
    Personally I am thinking of 290mm, but not sure if it will be an overkill.
  2. milo2025
    milo2025 Trip to Trumpton
    I know hardly anything about electric scooters but just wanted to say wttf (welcome to the forum) :)
  3. Sopheus
    Sopheus New Member
    Hahah, thanks :).
    I hardly know about bikes or mopeds myslef, but I guess shock absorbers on e-moped are the same to non-electirc ones. Would be much appreciated if you have any advice to give to me :D
  4. Stevep
    You should only need to change them if they are bottoming out when you hit the bumps.
    You might be able to adjust the damping to give a softer ride, but that can upset the handling if they are too soft, especially in cornering.
  5. Rickard Pingol
    Rickard Pingol Active Member
    Some shock are a bit tunable. Where you can adjust the preload on the spring. Maybe something to consider
  6. Mark Emerson Trentham
    I'd say you seem on the ball aiming for the middle ratio - better than going too low and having to buy another ;).
