right, i bought a set of cases from nrg andy, they had a malossi mhr crankshaft and a malossi primary gear up i then build my engine as normal fitted my polini sport to it etc but im finding it realy weak. with the exact same setup my topspeed was lower by about 4mph (give or take) and now im running my airbox again its dropped even lower to about 60 clock speed now it sets off ok and flatout is about 9500rpm, but im only seeing 60-62 at the very most, my standard 50 indicated that speed So in a nutshell, my 70 has become slower than my 50.... any opinions advice? thanks My current setup: Polini Variator 7gram rollers doppler s3r polini sport malossi crank malossi primary gear up standard carb and air box (102 main jet) oh one more thing, anyone have a clue why my main jets are always massive? was running a 142 jet with an open air filter, now on a 102 with bigger airbox. theres no air leaks etc cheers
Overgeared maybe... gearings too high for the engine to pull when flat out and hence its lost some speed?
7 gram rollers? drop them for the s3r pipe. need to go around the 5g mark, whip the filter off.. start around 78 and work the jeting down. deffo roller related
