Hey Guys I contacted a scooter parts place here.... They have 21mm carbs for around A$250 (112 pound) and CDI for $A125....(56 pound) i dont know brands and model numbers yet.... Is something like these in the right price range? btw... this is for my vespa et2 with a polini 70 kit.
ok...the part numbers are as follows: TC unit is 5513195 Carb is 1610997 for the 21mm these are malossi parts.... your thoughts?........
Piaggio CDI's are not restricted I thought....wasting your cash... If you have a 17.5 carb, just upjet it.... Look in the links section, and look up Scooter Center, check their prices to yours.....
piggy cdi is limited.. just need a silyl spec kit to hit it usually.. cdi is never a bad item to buy tho
hmmm i thought the carb was a bit pricey..... I might try to find a cheaper Dellorto carb locally.... What model carb should i be looking for? If i cant do that, I might get one from easy parts or something... they seem to deliver internationally. Is the price for the CDI ok?
evo/ported rep... anything made to rev past 14k... like this (tranny not setup); http://www.youtube.com/watch?v=WoH2bLaqihY&NR=1
has yours got a cdi dave? but ye, cdi and carb deffo, not sure about those prices tho. sure somone on here could buy on an send it over to you...
im just on std cdi at the moment... didnt think it was really worth changing with my half of a set up at the mo but when i get me shit together...will look for an unlimited cdi...
its a bit of an inconvenience.. but its possible.. probably somone else with more time and monies in there paypal could do it for ya. its worth a drink for the effort an is literally re addressing a box.
best bet is to place a wanted add asking for someone to contact you before they place there next order and come to an agrement for there hassel
not a bad idea stevo ill see if i can source one locally first for cheaper.... freight to aus might make it a bit expensive...... although, ordering straight from easy parts (inc 30 euros for freight) worked out about $50 cheaper..... btw... any one have the model no. for the dellorto 21mm carb??
ok... i found these from a pocket bike website: PHBG - 21mm A$189 (84 pound) http://www.ozminimoto.com.au/productdetail_right.asp?id=51&catid=72 PHVB 20.5 and 22mm A$159 (71 pound) main gets are around 5 bucks..... are these ok? are the dellorto carbs a direct swap.....?
