Best/ cheapest way to repair cracked panels
Discussion in 'The Workshop' started by typh-gilly99, Feb 1, 2018.
  1. typh-gilly99
    typh-gilly99 Member
    Typhoon 125 2T
    i got some cracked panels that need repairing, what’s the best way to repair and cheap epoxy resins to buy
  2. baileywhite
    baileywhite Member
    Fibre glass repair kit
    eBay or Halfords
  3. Buzz
    Buzz Active Member
    Fibreglass the inside for strength then once it’s hardened use fine filler on the outside crack. Prime, spray or put graphics over it.
  4. Stevep
    Double sided tape on the inside of the panel, spray some activator over it from some Mitre Mate, shallow skim of fibre glass, then OPEN up the crack on the other side with a dremmel so you can get some plastic bumper filler in there, sand it down, paint it.
  5. CGC
    CGC Active Member
    Piaggio Liberty 50
    depends on the severity of the crack, hammerite brush on paint can also be a good filler, before sanding. Spray the back of the panel with whatever your using for finishing, including lacquer, as it helps create a water seal. I know you have probably finished the panel by now. just thought I would share a tip.
