Bert the Hongdou
Discussion in 'Bike Chat' started by supraking, Jul 18, 2013.
  1. Mark Emerson Trentham
    Hey!,
    Don't knock it - there's usually someat down the road that'll probaly
    Fk. things up at some point!. :D .
    supraking likes this.
  2. supraking
    supraking Well-Known Member
    Honda MSX125
  3. supraking
    Honda MSX125
    righty, the idle is a tad high, until you release the clutch a bit when it dies down, so gunna have another little play with the idle.
    however when you give it some beans it seems to bog abit.
    not 100% sure how to remedy it, ive cleaned out the jets when i did the carb. maybe alter the other screw?
  4. Mark Emerson Trentham
    If it bogs a bit when you give it the beans- too much fuel/float height?,
    Would'nt have a clue 'bout throttle stop as never really had need to deal with.
  5. supraking
    Honda MSX125
    cheers bud, ill have a play around this affy
  6. Mark Emerson Trentham
    Keep an eye on your float needle an seat (both wear together),
    debris or particles can prevent it seating leading to a credit line with bp,,
    an if its too worn out won't seat proper.
  7. supraking
    Honda MSX125
    cheers mate will have a look (not that ill know what im looking for :) )
    on a lighter note, the gear selection lights actually work now :)
  8. Mark Emerson Trentham
    If you don't know what you're looking for,draw up a cpla carb. diagrams for examples (there will be variations)
    to give you the jist -unfortuneatly no pics at mo.
    The float needle fitting into seat creates an in/out level for
    flow adjustment,
    excessive wear or interference in that seal can fk. up proper running (starvation/flooding). :) .
  9. supraking
    Honda MSX125
    makes sense :) cheers bud.
    i really cant wait to get this thing on the road
  10. Mark Emerson Trentham
    So do I!,
    The stress is killing me!,
    An your the owner,giggle. :D .
  11. supraking
    Honda MSX125
    haha :)
    played around with the carb some more, still bogging. looks like it will have to come off and ill have a gander at the float
    now jsut trying to suss out the 'ignition barrel' lol basically a load of wires
  12. Mark Emerson Trentham
    Real serious issue with the wiring on the melody today,
    had to polish a bullett connector (snigger). :D .
  13. Mark Emerson Trentham
    Might wanna do the inner tube thingy with your float,
    bung it in a bowl of water - if it's leaking/you'll know. :) .
  14. supraking
    Honda MSX125
    oo winning cheers,
    think im getting somewhere with the ignition, gunna wire up the switch i got with it to the electrics part of the switch, then see if it kills the engine, if not abit more head scratching and i think i could sort it.
    failing that ive found a full barrel and lock set on the bay for 50 quid, but right now id rather not be spending that much on it
  15. Mark Emerson Trentham
    That sounds a bit dear!,i'd look about a bit more - though if it's a type specific purchase/more understandable,but still!.,
    (says the guy with a £5.00 bid on a complete 4t zip ala e/by. ;) ).
  16. scootzmadness
    seen them at £10 ....
  17. Mark Emerson Trentham
    Could'nt pull your bike up on e/by,but they are breaking a few cg's (complete!) an do posties,
    might be worth a recce. :) .
  18. supraking
    Honda MSX125
  19. Mark Emerson Trentham
  20. supraking
    Honda MSX125
    rofl :) well when its 3.39 i cant grumble at having to wait a week for it to arrive :)
