Areox Not running right ??
Discussion in 'The Workshop' started by Aerox_Joe, Apr 8, 2013.
  1. Jonathan123321
    Jonathan123321 Member
    Piaggio NRG Power DD
    have u checked the crankshaft oil seals ? Oil pump working correctly ? electrics working properly ? Checked all the pipes and filters ?
  2. steveaerox50
    steveaerox50 aprilia owner
    1999 aprilia rs125
    have you check'd the compression of the engine ?
  3. Aerox_Joe
    Aerox_Joe Member
    Aerox 50cc
    Thanks guys. My drive belt is very slack. I can push the too sides together? Should it be like this? Also tomorrow I will check the compression. Thank again
  4. steveaerox50
    1999 aprilia rs125
    when is the last time the belt was changed ?
  5. Aerox_Joe
    Aerox_Joe Member
    Aerox 50cc
    I don't know mate , only had the bike a few months and the owner. Didn't say if anything was changed . Should it be that slack or do I a new belft , also if it possible to tighten them ?
  6. Jonathan123321
    New belt !!! if it is that slack it will snap soon.
    steveaerox50 likes this.
  7. Aerox_Joe
    Aerox_Joe Member
    Aerox 50cc
    Ok mate , I know you said check the belt before but I only looked at the tread ha , will order new rollers and a belt now , hopefully that will fix it.
  8. steveaerox50
    1999 aprilia rs125
    that's probably why its sluggish the belt will be slipping it's tits off lol
  9. bashyy21
    bashyy21 Beaut!
    Have you tryed looking at the vac pipes make sure theres no cracks at all on the tank end, as my dna had the sane problem and slowly got worse over a month would startand ride and everything just very slugish, new vac pipe problem solved
  10. Aerox_Joe
    Aerox_Joe Member
    Aerox 50cc
    Ordered a new belt and rollers . Hopefully that will fix the problem . Thanks again everyone for the help :) :)
  11. Aerox_Joe
    Aerox_Joe Member
    Aerox 50cc
    Working well now , thanks again for the help :)
  12. Jonathan123321
    sweet as and np
