i have an areox thats around the 2004 edition of the bike an ive replaced the cdi coil battery and i have checked the flywheel stator works fine when you turn the key the dash works its had an engine rebuild to a 70cc i have also checked the pick up and its all fine also replaced the spark plug and spark plug cap twice and changed the fuses does any one know a fix need to know asap thanks for your time
Although changed parts have you checked the wiring also as may have a break somewhere Is the side stand down, needs to be up
