aprillia rs 28mm carb on a 172
Discussion in 'Maxiscooter Tuning' started by rideorcollide, Dec 15, 2009.
  1. rideorcollide
    rideorcollide Active Member
    TYPH 172
    yeah does sound like an airleak tbh, need to give it a proper check.
    its the same regardless of what i do to the carb, tried different jets, all needle positions, all idle mix positions, and the idle screw is all the way in.
    when i take it off the choke it sounds like if i had a boost bottle connected and it fell off or something if u know what i mean... got a vid anyway so ill upload that
  2. rideorcollide
    TYPH 172
  3. MiNoR cOnFuSiOn
    im assuming the idle mix screw is closest to the manifold not the filter, so all the way in should be lean, try it 4 or 5 turns out (just as a test) sounds lean as fuck...
    oh and grease the kickstart?!?!?!
  4. Runner-Joe
    Runner-Joe New Member
    Typh 125
    pmsl still gotta fit the mak10 word in ;) hehe
    good luck with it pal ;)
