Hi All.!! Recently i purchased a 5o cc Aprilia Motard, 2T..to commute to work,as i don't want to spend hours on traffic. Is a new bike with restriction to 30.i realised i need to keep up with the traffics so need more speed..-)). Because of the warranty the dealer not able to derestrict the bike.. So i need some help please..many thanks in advance.( just realised not in the right place posted.)
Hi. The hell with the waranty. I don't know your ped but there are two things you need to do: Remove the variator pulley and take off the restrictor ring that stops it opening up. Remove the standard exhaust and replace with a propper expansion chamber exhaust. Unless you have a pneumatic wrench and a box of jets/ rollers, this will require assistance. Find a good garage - and discover what you've been missing!
The std pipe work's very well once derestricted, upjet from a 53 to 58-60 with std pipe, also remove brass plate from carb mouth, thn washer out the variator. If it goe's bang then it on your own back to fix it.
On a lot of Piaggio engined scooters (sr 50, nrg, zip)there's a gold coloured plate on the mouth of the carb with a 3-4 holes in it, this is a restriction. I can put up a photo of one if you want?
-) Hope this helps you..the guy just taking of the factory restrictions and the bike does around 50-55 MPH.you can that vid as well.
