aprilia sr 125 jetting
Discussion in 'Maxiscooter Tuning' started by andrew jones, Jul 11, 2019.
  1. andrew jones
    andrew jones New Member
    scomadi 125cc 2 stro
    looking for advice on jetting on a standard 125cc engine with a foam pod filter.i have a selection of jets but would rather start rich and work down as i heat seized my last cylinder riding with no airfilter
  2. MARSH
    Start big and work down, or the best bet is to put the std air box back on it !
  3. scubabiker
    Put an airbox on it.
    If you are running anything less than a custom racing engine it's going to run best with an airbox
  4. andrew jones
    no room for airbox i wont fit the panels on
  5. scubabiker
    There should be. They make it with an airbox.
  6. scubabiker
    Wait is it an engine swap maybe?
  7. andrew jones
    its a scomadi 50cc converted to 125cc 2 stroke airbox would be too big panel wouldnt fit.ive fitted biggest jet ive got a 110 and will work down
  8. Sam phantom
    Sam phantom Active Member
    Is this an early air cooled unit?
  9. Sam phantom
    For the air cooled unit From past experience 100 with a k&n open air filter was my sweet spot. May not help you tho as there all individual
  10. MARSH
    What carb is it ? Dellorto or Mikuni ?
  11. Stevep
    A scomadi 50 converted to 125????
    What crank have you used?
