Aerox taking the piss..again
Discussion in 'The Workshop' started by Chubz, Sep 15, 2012.
  1. Chubz
    Chubz Well-Known Member
    70cc Aerox 04'
    Its not a fuel problem... fuel is getting all round the bike where it should be we've already checked...., changed plugs ....nothing.
  2. oldbugger
    oldbugger New Member
    Could the other screw be the pilot screw, try screwing it in 'GENTLY' till it seats then turn out two and a half turns and try to start it
  3. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    You using fresh petrol?
  4. Chubz
    70cc Aerox 04'
    Yeah using fresh petrol mate...tried literally everything i can think of and nothing has got it running o_O
  5. c0nn0r77
    c0nn0r77 Member
    Aerox 70
    take it back to the shop, if you spend 500 on them fixing it and it wont start tell them to do a proper job and refuse to pay
  6. Chubz
    70cc Aerox 04'
    too late ,, they aint gonna do that....... plus already paid the mugs
  7. Callum Coles
    Callum Coles 2003 Piaggio Zip Sp
    2003 Piaggio zip sp
    post up a vid of you trying to start it makes it alot easier to try and work out the problem then lol
  8. Chubz
    70cc Aerox 04'
    ill get one up tomorrow mate as its all in bits in the living room atm lol...
  9. Callum Coles
    2003 Piaggio zip sp
    lol okay mate
  10. oldbugger
    Did you try the possible pilot screw adjustment
  11. Chubz
    70cc Aerox 04'
    Not exactly sure where that is lol... if its one of the screws on the carb next to the idle screw, iv tried it....if it isnt...then i probably havnt lol......
  12. Callum Coles
    2003 Piaggio zip sp
    yes the screw nearest to the air intake side is the pilot the one that comes out of the carb usually has a spring around the shaft is a idle screw.
  13. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    What state is the plug in does it get wet with fuel when it turns over.
    Humour me, try putting a short reach plug in cos if it's overfueling and the plug is getting wet it won't start, but a short reach plug is tucked out of the way and tends to stay drier and works. if it fires up with the short reach plug then your problem is either too much fuel or not enough air ( remove snorkel).
  14. Chubz
    70cc Aerox 04'
    Pretty sure it does mate, iv gotta get a video , family member died this morning so have been occupied elsewhere ...
    Its already got a short reach plug mate, this conshop told me the long reach was too close to hitting the piston? so they changed it for short reach and the bike started o_O confusing thing,.... and the snorkel was removed as soon as i got the new airbox lol... seemed to work fine with the 100 jet in, but anything smaller an it wouldnt start... iv got a video of when it started ill upload that now if i can,(photobuckets being a whore) lol...
    And ill go put the bike back together now and get another video of the nasty sounding kickstart
  15. Jonnymarrw00t
    Piaggio Zip 05 plate
    Message me on facebook mate, Need to speak to you :)
  16. Chubz
    70cc Aerox 04'
    Okie dokies frank :)
  17. fallon
    fallon Member
    Piaggio Zip 50
    Have you tried to put a bigger jet than 100? and maybe try to start without the exhaust, it will sound disgusting but it might work and I believe the standard setting for the idle is 1 1/2 turns out
    I would also have a look at the needle in the carb and the idle screw my mate had a problem like this with his crosser everything seemed like it should work but nothing, turned out he broke the needle or something.
  18. Callum Coles
    2003 Piaggio zip sp
    wait how the fuck does it even start on a 100 that massive for a 70s
  19. fallon
    fallon Member
    Piaggio Zip 50
    easily i know people running 70 with a 135 jet o_O
    all depends on bore air filter and exhaust
  20. Jonnymarrw00t
    I run a 120 on my zip lol
