Aerox stage 6 sport pro help!!!!
Discussion in 'General Scooter Discussion' started by Jimmy yates, Apr 28, 2012.
  1. Jimmy yates
    Jimmy yates Member
    It's 2003, So I basically use the tool to get the flywheel Nut off after taking off the water pump and all that, Then basically the the stator and flywheel slide off and that's it for that side?
  2. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    There's two types of pullers for the flywheel one which screws into a thread in the centre of the flywheel and one which uses two bolts which thread into the holes used by the waterpump drive pegs. If your flywheel is threaded in the centre hole you need the first type, if it isn't like mine, the second type.
  3. Jimmy yates
    Jimmy yates Member
    Oh right ok so after I've got the flywheel off does the stator just slide off?
  4. Mr Bizzle
    04 Aerox 70 stage 6
    You undo the flywheel nut then use the puller to remove the flywheel . the stator is then held on by a few allen nuts. Next remove a gasket and then the oil pump and drive cog. It;s all very basic just keep everything in orfer and dont lose the woodruff key which locates the flywheel.
    When I replaced my crank I found that the grove for the woodruff key in the new crank was narrower than the key itself so the key had to be trimmed to fit.
  5. roxy boy
    roxy boy Well-Known Member
    roxi
    btw the stage 6 sport pro is no longer sold anywhere and to run it it takes around 30mins for an alloy and
  6. Jimmy yates
    Jimmy yates Member
    30 mins for an alloy? They do just the mk2 sport pro
  7. roxy boy
    roxi
    y
    it only take a few heat cycles on idle then on half throttle then on full throttle and yes which has a LOT of power it is ment to have 15bhp standard and with porting and flowing up to 23bhp ...
  8. Jimmy yates
    Jimmy yates Member
    Oh right!
  9. Jimmy yates
    Jimmy yates Member
    What's the stage 6 racing like?
  10. roxy boy
    roxi
    it has good power and will be reliable but will take ages to run in
  11. Jimmy yates
    Jimmy yates Member
    Yeah, How long do you reckon? 200 miles?
  12. CA Zip tuning
    CA Zip tuning Member
    Apparently i shouldnt get a stage 6 race, what are the pros and cons i have a air cooled zip, thanks
  13. Jimmy yates
    Jimmy yates Member
