Scooter Shack Scooter Forum
ForumsThe Tuning CenterScooter Tuning
Aerox stage 6 cylinder head help?
Discussion in Scooter Tuning started by kizza_93, 22 Nov 2010
kizza_93#1
hi just bought a new stage 6 streetrace 70cc kit as my old kit blew up but ive fitted it all on the new piston, rings etc etc but i have to use my old cylinder head because on top of where the temperature sensor and thermostat thing goes theres like two miniture holes which is water recycle system and water to warm the carb up but on my new 1 there is only 1 hole so if i connect my water to it im thinking it will go through to my engine my just straight out which means constant top ups is there anyway of doing it different as i need the new head on because the old 1 keeps leaking because my nut/bolt keeps falling out of the top left corner cause head gasket to as it did with my old kit? Thanks would appreciate the help, kieran :)
capri dave#2
:scratch: any chance of a picture of the problem, because im not 100% sure i know what your talking about....but
you dont have to run the water circuit for the carb heater if you dont want, i havent had the carb heater circuit on my last 2 carbs, its optional :)
kizza_93#3
You answered it already mate :) Thanks and some1 else previously helped me out but yeah that was alll i really needed to know was can i run the cylinder head off 1 water recycle hose or will i need 2 so i can warm carb up too but thanks :good:
yasuni exhaust help10 replies26 Nov 2010
Aerox going to 50 then nothing26 replies25 Nov 2010
renthal bars for nrg?2 replies24 Nov 2010
Piaggio zip 70 kit Trouble . . . lots of smoke5 replies23 Nov 2010
cast iron 70's7 replies23 Nov 2010
what 70cc kit + exhaust works better together4 replies19 Nov 2010
Warp drive?5 replies15 Nov 2010
70cc corsa minarelli3 replies14 Nov 2010
typhoon setup.10 replies13 Nov 2010
typhoon open air filter8 replies13 Nov 2010
