Aerox set up.
Discussion in 'The Workshop' started by Jimmy yates, Jun 7, 2012.
  1. Jimmy yates
    Jimmy yates Member
    Ok mate thank you! Also my cylinder head ATM has 2 pipes and 2 nipples ontop of the cylinder, the streetrace has only 1 nipple and no pipe? Do you know what they are and what do I do? Thank you!
  2. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    The standard head has 2 nipples to feed hot water through the carb. The streetrace does away with this but has the bleed nipple to remove any airlock which would stay in the head and cause a hot spot.
  3. Jimmy yates
    Jimmy yates Member
    Oh right! So it would be fine to remove both of the tubes going to the standard cylinder head? Or would it damage the carb? Or would it be better to just use 1 pipe on the 2 outputs on the carb?
  4. Mr Bizzle
    04 Aerox 70 stage 6
    The two nipples on the standard head have no valves they feed and return hot water to the carb to prevent the carb from freezing in extremely cold weather. The nipple on the streetrace is a bleed valve only it is not designed to feed hot water to the carb. Running without the hot water through your carb will not be a problem unless you intend riding in subzero temperatures and even then the position of the carb out of the airflow and above the cylinder will probably be enough to stop it from freezing.
  5. J4M1E
    J4M1E New Member
    Hi im new to this i have a 2010 aerox and ive just fitted a stage6 70cc street race kit,stage6 pro rep exhaust, standard variator with stage6 4.5g rollers, stage6 medium clutch springs, stage air filter for the standard air box, standard carb with 72 jet it splutters abit when pulling away and only does 30mph it just doesnt seem responsive only way to get it to move is keep the throttle on full
    Im stuck and dont what is wrong with it any suggestions ???
  6. Mr Bizzle
    04 Aerox 70 stage 6
    Have you removed the restrictor from the variator? if not do it now and bin the variator while your at it. The standard variator is not very good and it is the first thing which you should change.
  7. J4M1E
    J4M1E New Member
    I was thinking of getting a new variator but cant afford it at the minute what is restricting the variator? Ive spoke to a local bike shop they have suggested that the fuel and mixture isnt right resulting in my problem
  8. Mr Bizzle
    04 Aerox 70 stage 6
    Have you removed the restrictor washer between the variator cones?
  9. charliemcmurray5
    charliemcmurray5 Member
    omg you guys dont understand how much trouble and cost ive had with my ped because i was not bleeding it properly and i think im gunna copy your guys set up it sounds mint :p
