Aerox running like a piece of sh*t
Discussion in 'The Workshop' started by White aerox, Feb 23, 2008.
  1. MiNoR cOnFuSiOn
    coz he didnt lighten the rollers...
  2. White aerox
    White aerox New Member
    he did didnt think that wud make a difference he had 5.2 and put in 4.2 malossi rollers still bogged reallly bad cudnt even move it, getting way to much air so how do ppl stop the bogging down
  3. J-Nitro
    J-Nitro Active Member
    your rollers are too heavy on a rox they should be nearer to the 4 mark not much for than 4.5 usually especially with the pipe youve got
    try 3,5 and 4's
    gap your plug like dave said it should be .65mm on a minarelli horizontal engine
    plug type: BR8HS/B8HS
    have you done a plug test since youve modified the engine?
    dont bother with a filter they cost your more money and time and hassle
    trust me on this one, the stock box is better, to get a little deeper sound pull the long tubular rubber out the box next to the inlet pipe
    I get around 30-40 less miles to the gallon with a k+n, which, if you dont work will piss you off in no time i bet unless mammy and daddys been paying for the fuel bills ofcourse
  4. White aerox
  5. wobbly_trials
    i beleive the malossi kit needs a longer plug so the BR8ES is the one you want
    and irridium is more money than its worth.
  6. White aerox
    lol so i have got tht iridium plug for nothing and i will buy that br8es will tht stop the spluttering thanks
  7. White aerox
    wobbly i just looked on scooter-attack where i got my kit from and in the spare parts section i says this plug: Spark Plug NGK (short-threaded) B8HS (W3AC) is that right or wrong plug cos if am getting another plug!! then i want the right 1 if u no wt a meen lol
  8. Aerox Aaron
    Aerox Aaron New Member
    are you running on standard airbox, because my bike was spluttering from not getting enough air.
  9. White aerox
    yes standard airbox mate
  10. Aerox Aaron
    Drill some wholes in it , nearer the top, more prone to water if not
    did mine last night, makes it alot better
  11. White aerox
    well i have a e5 airfilter tht i want to fit mate but it just bogs down when i put it on
  12. Aerox Aaron
    Can't say im an expert on on airfilters, just when i started bike without airbox on it ran sweet, with it , it bogged down.. so it was just common knowledge to know it was bogging due to air.
    Can't help ya on the e5 filter matey
  13. White aerox
    ok well anywyas this spark plug can anybody else with a malossi sport kit tell me what spark plug they have thanks
  14. White aerox
  15. J-Nitro
    std. i used a longer type and it didnt fire up all of the time for some reason
  16. WOLFFY
    WOLFFY New Member
    BR8ES NGK R is what I am using on my 70 kit. I was thinking about getting a BR9ES as my bike loves to eat spark plugs.... :wtf:
    But I think I am going to try out the Iridium plugs. See if they last longer.
  17. White aerox
    ok i have just bought a br8hs spark plug from a scooter shop it is deffo the right plug but it is still pluttery and power has been lost, and throttle response it seriously bad i full throttle and it takes about 2 seconds to move not happy at all. ok people so what is the next stage 2 check out
  18. WOLFFY
    WOLFFY New Member
    BR8HS is short reach I think. Im using a long reach plug and it is running fine now.
    Take the plug out and say what color it is.
    Also have you checked to see if your jets are blocked?
    You are better off keeping your air box as the weather is so unpredictable
  19. White aerox
    your using a long reach oh tthe person said i needed a short reach but it isnt the spark plug as i had along reach iridium plug and it was still pluttery i will check for blocked jets it does feel as thou it isnt getting enough fuel thorughthats why power is lost and its spluttery thanks
