did you make that or buy it, because am not going to lie it looks shit Sorry. EDIT: or is it not fitted the in the last photo? it looks too big and out of shape
You are right Had to fix it afterwards I bought one similar to my speedfight and must say that the fit was worse than my own first attempt!
Everything came with the order! Malossi - Primary Drive (13/44) 1:3,38 Malossi - Secondary Drive (14/43) 1:3,07 Malossi - Variatorkit (MHR) Overrange Malossi - Clutch Kit (Delta Systems MHR) 107mm Polini - Clutch Cover (Evolution) Carbon (P170.0302) Polini - Gearbox casing Evolution (Minarelli) This weekend it will be installation time But still missing the exhaust!
New gears in place! New gear ratio 10,396 (18% increase from original) Look how i did it in this link http://www.scootershack.co.uk/threads/aerox-guide-replacing-the-secondary-gear.29187/ Removing starter to get some room for the new variator Check the condition of the starter
Starting to give som space for the Malossi MHR overrange variator with a grinder Not ready yet but some progress! New variator has a diam of 97 mm the old one is 94 mm And the diam of the new weights are also bigger Everything soon in place Need a new kickstarter
Thank you Mounted the kickstarter yesterday How to "clip" in swedish I'm not a pro Had to do this ten times to make it look so easy
And check out the text version here http://www.scootershack.co.uk/threads/aerox-guide-replacing-kickstarter.29311/ Hope you like it
Waiting for parts...brake discs.. But then i can work on my other Aerox Did som painting and grinding.
The frame this morning... Start working.. Some new vinyl on the shocks And the new Stage 6 oversize brake discs
I want a manual petcock instead of the vacuum controlled petcock. So i "modifyed" the vacuum controlled petcock and installed a manual petcock on the petrol hose.
Oversize Disc and brake calipers BUT no caliper adapter Forgot to order the caliper adapter ... So job will stop for a few days AGAIN .. ________________
