Aerox barrel studs
Discussion in 'The Workshop' started by AeroxJoe94, Jul 4, 2014.
  1. Stevep
    then the clutch is engaging too early, change the clutch springs for stronger ones. If you look at the ones that are in, count the coils, you've probably got six coils at the moment, change them for springs with 5 coils first, see how that goes, then if you think it still a bit boggy change them for 4 coils.
  2. AeroxJoe94
    AeroxJoe94 Member
    I have tried the clutch from strongest to weakest with every combination of all torque springs and still no luck so I'm really stuck
  3. Stevep
    not the torque spring, the clutch springs, on the clutch slippers
  4. Stevep
    These little buggers shown in white:
  5. AeroxJoe94
    AeroxJoe94 Member
    Yer I have changed the three clutch springs from standard and tried 3 different strength springs none of them have made a difference
  6. Stevep
    Ok, what size main jet have you got in the carb?
  7. AeroxJoe94
    AeroxJoe94 Member
    82 I think but I have got a full box of jets from 70 to 110 and 82 was the best anything different and it ran terrible
  8. AeroxJoe94
    AeroxJoe94 Member
    The spring slider that you can see in the picture you posted, I have not got that in behind my clutch
  9. Stevep
    And you have the standard airbox on?
  10. AeroxJoe94
    AeroxJoe94 Member
    Yer standard airbox
  11. Stevep
    I've just had a similar problem on an NRG;
    if your mate is agreeable, can you use his entire clutch setup, clutch bell included, fit it with stronger springs, and try that.
    The nrg i mentioned, i had to put it back to standard everything clutch wise, other wise it just wouldn't pull until 20mph.
    Where about in the world are you located?
  12. AeroxJoe94
    AeroxJoe94 Member
    It's just been doing my head in.... And I'm from north east england close to hartlepool, when I had his whole rear pulley clutch set up in mine it revved before pulling therefor better acceleration, the thing I don't understand is that my clutch is engaging earlier even though I have the strong springs fitted
  13. AeroxJoe94
    AeroxJoe94 Member
    I have not got access to compressed air is there any othe way to get any bits of metal from the circlip out of the bottom end?
  14. Stevep
    only one other way to be sure.............out comes the lump and strip it. Dont want loose metal floating around inside:(
  15. AeroxJoe94
    AeroxJoe94 Member
    If it loose would a magnet not do it :)
  16. Stevep
    and if it isn't?
  17. AeroxJoe94
    AeroxJoe94 Member
    Suppose to be safe il have to go to a local car garage and use their compressor
  18. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    It's got to be the clutch - not stiff enough and / or the mixture screw and possibly that the variator needs a washer (like in the video). But you need to put stiffer springs in the clutch for a start. I use black Omega springs in my Gal's Malossi delta - (which are so stiff that actually getting the buggers in there requires some fairly hefty hardware and not a little effort).
    For my scoot - even that is not enough. The wings of the clutch have been removed and drilled identically in a drill press to remove weight. Less weight requires more revs before they stick. If the clutch is like the one in the photo, take it apart, put the wings in a vice and saw off the last 10mm of the wing. Alloy, pad, the lot. 10 mm. Then weigh them to make sure they weigh the same. Adjust with a file (or a Dremel) - put it back together with the stiffest springs you can find and tell us how it went.
  19. AeroxJoe94
    AeroxJoe94 Member
    What I don't understand is I have tried really hard spring in my clutch and it hasn't improved. But when I try my friends totally standard clutch and springs it revs nicely before pulling. Mine just pulls straight away but with no power, could this be down to mine been brand new and the pads may be a little bit worn down on his therefore having to stretch further to contact the bell?
  20. turbovetto
    tweaked ovetto
    Quite possibly. Or it's possible that your bell is too small for the clutch and it's contacting too soon. What brand of clutch is it ? Polini ?
    Have you set the adjustable bits as far in as they will go ?
