Hi I've just rebuilt my aerox engine has a 70cc mallosi mhr rep head and piston Mallossi crank Stage 6 bearings 17.5mm carb Mk1 stage 6 pro rep exhaust Polline variator 6g rollers Stage 6 clutch with soft contra spring My issue is it has no pullaway power and struggles to get to 30mph I have tried all sort different jets which gets the bike running perfect on the stand but as soon as I pull away it has no power. I've tried a stage 6 oversized variator with 3.5g rollers aswell and have the same problem Have 125 compression
You really need to start with one tuning thing, barrel 1st, see how it runs then fit other parts so you know what's working or not ?. You'll need to work it out to find what works .
