why you getting loads of parents for xmas ? arc: ditch one of the gear ups mate and grab a bigger carb
which would have more performence gains tho the carb, or the gear ups and could someone please tell me which is the most reliable crank for the money
gear up kits give you about 10mph extra top end but you sacrifice some of your 0-10 acceleration to get this.
Dont use more than one gearup kit, its a waste of money and will perform worse (assuming the malossi 70kit you tryed linking too was the malossi sport or MHR-Rep) spend the money for the second gear-up on a bigger carb instead. With a malossi sport or MHR rep id just use the standard crank until it eventually packs in, then replace with something better, as neither of those two kits will kill a standard crank very quickly.
this is the set up i am currently looking at would this be fine Polini corsa 70cc polini race crankshaft malossi 21mm carb doppler air system malossi clutch springs (green,blue, red) malossi gear up kit and a box of rollers and jets...but im not too sure on what roller or jet size to get !! ?? does this setup sound fine, i am fairly new to scooters you see
and would this still be fine with a leo vince tt i have or would i be looking at getting a yasuni city 16
the corsa barrel has yasuni c16 written ALL over it... more so than the mhr rep (only reason to run the 16 on the rep is lack of a better pipe.) corsa's are like a cross between the evo and the iron, iron kit wiht the wider exhaust port (single) and roughly the same port timings as the evo.. best of both worlds really.. tad expensive for what it is but it would cost you more to buy an iron and cut to corsa spec
cheers man i might wait a bit before getting the gear up kit as i dont have that much dosh :emb: but thats the setup i think i may definately get unless there is a cheaper crank out their ?? that is still good quality and also could anyone recomend me jet and roller size, or shoul i use the rollers that come with the yasuni??
rollers and jets you should just have lots of them.. any enthusiast should... bgm cranks (made by bi di zem/blata NOT pm tunning) are great quality.. around 100 quid or less aswell so a worthwile investment.. have yet to see one fail and they have been about a while.
Code: cheers man do you know where i can get the bgm crank from and will it be compatible with the corsa also im looking at the 21 carb by delorto but also cant find that either im mainly looking on adrenaline pedstop atm
yep.. any of the euro sites in the liunks section.. cheaper and quicker than uk stockist belive it or not.. match the gudgion pin/small end bearing size.. (10 or 12mm respectivly)
http://scooter-center.com/catalog/produ ... 8_288_2468 would that carb be fine with a stage 6 air filter on the end
yep.. altho you can get a dell 20.5 from a runner 125 an bolt it striahgt on (prittymuch the same thing) both will require a longer cable between the splitter and carb
alright man cheers for all this so much help man and i think im going to go with the evo 2 race clutch
the 2g is easy as pie to setup.. altho for this kind of setup isnt relaly rewquired.. set of springs will suffice
read about.... theres PLENTY info about if you read a bit.. nobody's gonna go into thing's as thouroughly in new threads abotu what they have talked about in new threads for years... old threads people love to add too.. as it makes em a great read, easy to find and you learn alot more. in other words.. i cant be fucked to answer that
