Advice required
Discussion in 'The Workshop' started by Puddlesurfer, Oct 5, 2017.
  1. Puddlesurfer
    Puddlesurfer New Member
    Hi Guys,
    I'm looking for a bit of advice, I'm going to replace the exhaust on my son's 'ped.
    It's an AJS Firefox 50 2 stroke. The problem is no one lists parts for AJS, I know the engine is a Chinese knock off of another engine but would any of you guys know which engine it's a copy of?
    Or can anyone recommend an unrestricted/racing exhaust that will straight swap/Swap with little modification?
    Cheers,
    Puddlesurfer
  2. scubabiker
    Copy of a minerelli maybe?
  3. Sam phantom
    Sam phantom Active Member
    Do you have pic of the pipe off the bike? And I might be able to tell you if it looks the same as mine
  4. Stevep
  5. Puddlesurfer
  6. Stevep
    Most exhausts come with the restrictor already in, even the aftermarket sports ones, either you or the seller can take it out.
    It might be worth a check with AJS if the standard exhaust has a restrictor that can easily be removed.
    That way you get all the power and none of the noise associated with "sports" exhausts.
    I did this with the Technigas silent pro, all the power, half of the noise.
    scubabiker likes this.
  7. RLH5
    RLH5 New Member
    So, I've just had a new Technigas exhaust from eBay for my SR125, are you saying it could have a restrictor of some form fitted to it? How do I tell?! Thanks
  8. Sam phantom
    Not on a 125 it won't
    RLH5 likes this.
