a book and a barrel
Discussion in 'Scooter Projects' started by shiny red, Mar 20, 2008.
  1. MiNoR cOnFuSiOn
    follow instructions an go at it one last time with the sanding drums.. get the corners first then work back to the middle with the small ones. then switch to the bigger drums to flatten it out.. just KEEP the tool moving with the highest spot centre or ether end the swept area. if you try and remove a lump statonary you will create a grove. tool moving fast wiht low rpm/force
  2. shiny red
    shiny red New Member
    will do :punk:
  3. WOLFFY
    WOLFFY New Member
    Can any one tell me the basic's of porting. Or point me in the right direction of getting a understanding of it properly? Been looking at Dremels, Would you say go with a genuine Dremel or will a lookalike do? As I have three 50 barrells and a 70 barrell laying about. Would practice on the 50's just to get the basics then transfer it onto the 70. Cheers.
    Good work Shiny ;)
  4. Sw1fT
    Sw1fT Active Member
    200SX S13
    get a genuine dremel and put some electrical tape over the switch when you're using it (thanks minor, already had to pull mine apart and clean the switch out)
    there are a few rough guides around for porting, some small sections on here as well, i believe there is some help on this thread aswell. Have a look for any books you could read up about it in, two stroke performance tuning by graham bell is very good.
  5. shiny red
    i got my dremel type thing from homebase it came with a pencil extension which is alot easier to hold than a big dremel ,a stand lots of bits all for 29 quid ?its cheap but seems to do the job ?its the burrs and sanding blocks that cost the money???give it a try wolffy as minor said to me"wots the worst that can happen" :D
  6. shiny red
    put shiny back together today just to try wot i have done so far?OH MY GOD i have been riding a 4t :wtf: shiny feels like a rocket i will take some vid tomorrow?????????????i have not even finished yet?its like a motorcrosser :bird:
  7. kyle1b1
    nice :D
    can you tell difference your work has done ?
  8. numanoid1704
    numanoid1704 New Member
    shiny
    hi shiny,good to hear shes running again :D get the vids up soon :D. cheers
  9. wobbly_trials
    nice to hear she's running
  10. MiNoR cOnFuSiOn
    *waits for removal of barrel for more work*
    well done m8. may need heavier rollers in it now tho ;) still running the scorp?
  11. monty9120
    monty9120 Active Member
    Vespa gts300
    i think hes running an nk sprint now
    thats why the motorcross noise :w00t: the pm and nk are the only pipes that sound like that
  12. MiNoR cOnFuSiOn
    that alone will give a good gain in rpm..
    how you liking the ringing in your ears after a long ride? :D
  13. shiny red
    long ride i wish?maybe just new toy joys but it runs so much better than before ?yeah got the nk on it flies been to wet today to get a vid done?thanks for doing the crank wobbly and thanks minor for all you help top blokes :punk:
  14. MiNoR cOnFuSiOn
    no worries... :D
  15. shiny red
    put a vid up c vid section :w00t:
