Hello! I own a Gilera Runner 125 (4 stroke LEADER engine). The bike runs extremely well. However when you have a passenger on it the bike struggles a little bit and you have to squeeze the engine in order to accelerate as it has its maximum torque on high rpm. So, I was thinking for an affordable and as much as possible a reliable solution. I thought that I could install the cylinder kit and the camshaft of Runner 200. With this solution I can gain some torque and a minor hp upgrade. First of all, is this "mechanically possible?" If yes, do I need some more parts of the 200cc bike? Thanks in advance John
I'm pretty sure the 172 or 180 standard upgrade will just bolt straight on. Have a look at pmtuning website.
Yes I know its a 4t, pmt used to do a 180 for it but looks like its now discontinued. Here you go, got plenty dollars? http://www.pmtuning.co.uk/m3113955
I know the Malossi cylinder kit solution. The "problem" is that in order to make the most of this cylinder kit, I have to buy the V4 head too which triples the cost. That's why i was thinking of the Piaggio 200cc cylinder with 200cc camshaft which is a more affordable solution.
