2007 Speedfight 100 will not start
Discussion in 'The Workshop' started by Stompingbinkie, Apr 2, 2013.
  1. Stompingbinkie
    Stompingbinkie New Member
    Hmmmm I think maybe my oil pump has given up then and the lack of power was down to it seizing up?!
  2. Cockers
    Cockers I hate speedfights
    Not to sure you can run them with out the pump Cox you cab pre mix so its doubt full
  3. Cockers
    sorry for some of the typos, My phones a pain I was at work! I doubt your oil pump is causuing it to cut out because If I'm correct it's mechanically driven so when the engine turns your oil pump pumps.
    You can run a scooter with out an oil pump because you can premix It sounds more to be a fuel or fuel mixture problem hope you get it sorted! If its the standard carb which is a gurtner they are the most unreliable piece of rubbish ever! I have a spare gurtner that needs a float put into it for 15 quid if it comes down to a carb issue!
  4. LukeD
    LukeD ZIp-Zippity Zip
    Piaggio Zip 50
    Take jets out the carb and clean, if all clean, then sounds like your cdi has packed up, my friend had a 2007 100cc speedfight and his did the same thing, it would run, then die, then run again then cut out, apparantly its usual for the cdi to go on a speedfight, so see if you can source a cdi to try
  5. Cockers
    That I did not think of purely because I aint had the problem with a cdi touch wood!
  6. LukeD
    Piaggio Zip 50
    Yeah i checked over everything listed in this thread when he had his speedfight, could not wok out for the life of me why it would not run when opening throttle up, so i rang around a few places, and they all said the same thing, most speedfights before 2008 that have these symptoms all have the same problem, or so those mechanics told me, so obviously common lol, i replaced his cdi, and hey presto like nothing ever happened
  7. lordtaylor20
    lordtaylor20 New Member
    Speedfight 100
    any chance i can get a copy also please???
  8. lordtaylor20
    Speedfight 100
    ok.... 2005 (i think) speedfight 100... couple of issues, if anyone can help
    having problems starting with starter switch... clicks or just a whine, starts after a couple of tries with kick..
    also... speedo and fuel gauge don't work once started
    been left for 12 months ish outside. had new cdi last year, and i've just replaced the ignition block (original owner lost his keys!)
  9. Bouncer
    Bouncer New Member
    Can u email me a copy please richardgoshawk@gmail.com
  10. Bouncer
    Bouncer New Member
    Ok my speedy just had a engine rebuild as my problem was a massive crack in engine I wouldn’t get enough power felt like I was riding a 50cc and I got a 100 lol was firing up mind I had to cover the air filter hole on my 21 mm carb to fire it up but now not even firein up I put petty down head and wants to but doesn’t ???? Any help guys would be great
  11. Bouncer
    Bouncer New Member
    What happens if you self mix your oil and petty ?? Surely you don’t need enough oil in tank then ??
  12. CGC
    CGC Active Member
    Piaggio Liberty 50
    do you have a good constant spark. or maybe you adjusted carb settings while not having as serious a leak.
  13. Bouncer
    Bouncer New Member
    That’s what I’m tryin now changing jets in carb it was running with 100 jet befor the engine rebuild what do you rekon , becos it doesn’t seem to be gettin enough juice to plug But I don’t no how high to go ??
  14. Stevep
    WOW! Talk about hijacking, this thread is originally 5 years old.
  15. CGC
    CGC Active Member
    Piaggio Liberty 50
    this thread may hold the record for the longest gap between posts, but the man needs help anyway. though should probably start a new thread. :)
    Bouncer likes this.
  16. Bouncer
    Bouncer New Member
    Sorry I was reading up trying to figure out my problem and thought I’d ask I don’t even look at the date it posted aha sorry
    CGC likes this.
