ok so i picked this up today from some teenage girl who didint have a clue what is she selling she used it on a fields so probably crashed it few times this is where the scratches are from.. it dont start but all the electrics work i think that the problem is in piston rings/bore as it kicks very easy and there was no air filter when i got it. so will have some updates soon btw i got for £150 and its 54 plate some pictures: aerox is not alone anymore
wow you got yourself a bargain with that typhoon my friend and very nice aerox what your plans to do with typhoon?
thanks mate, and im thinking of some sort of a stunt bike, i have a clock bar ( wheelie bar) so thats going on it , engine: will keep the leovince pipe for now getting maloossi sport 70cc malossi multivar kit keeping the 17.5 carb stage 6 belt pmtuning reed block stage 6 straight intake malossi covered airfilter Looks: not sure about the color scheme yet naked bars and stem tnt front light smoked lenses ice bracket not much else i can do for looks , and engine will be budget reliable 70cc, any suggestions very very welcome
Nice set up your thinking about if your really on a budget instead of malossi kit why not try athena 70s ive got that and is true power for stunt bike and realiable as for visual u should do white inner panels with lime green
ok so i had some work done today, found out the problem , instead of petrol tap there was some random filter that was only getting petrol into carb non stop, and the vacuum pipe was just there unconnected, i got the engine out but havent got any pictures of that yet.
Piaggio Malossi Cast Iron 70cc Kit Air Cooled Stage6 Drive Belt - Piaggio Malossi Race Air Filter (Covered) Malossi Multivar Variator Kit- Piaggio PM Pro Street Carbon Fibre Reeds Valve STR8 Handlebar stem - Piaggio/ Gilera TNT Handlebars Transmission Cover/ Side Casing Bolts STR8 Fairing Indicators - Small, Round Piaggio Typhoon Clear Lens Kit Vacuum Fuel Tap, Aerox, Piaggio/ Gilera Sigma Bike Digital Speedo Clock Indicator Bulbs 10W Fuel Hose/ Pipe(red) Malossi MHR Sticker ORDERED !!!!
done some work: most parts are now cleaned forks sprayed headset got new grease frame cleaned will have some more pictures on wednesday
got a question: will i need to premix it on my set up? having in mind that this bike will be on its back wheel all the time?
oh and i decided on my color scheme: very dark grey glossy panels white glossy wheels and some little parts sprayed in gold )))
i like it so much so cleannnnnn!!! btw that shock is the malossi one?? or im wrong? also the premixing thing sounds to me quite stupid :/ cant really understand how it will work properly, since the oil will all go down with the fuel... anyways the color scheme sounds nice! cant wait to see more of this monster
i made that shock look like malossi one but its just the standard one lol, and fuel would go down with oil so there is no need for it to be mixed in a carb + if i wheelie alot oil will struggle to get to carb and if i premix it will go there with petrol straight away , i,ve done some work will upload some pictures soon !
