Piaggio scooters wire schematics
Discussion in 'The Workshop' started by Tamiyacowboy, Jun 17, 2017.
  1. Tamiyacowboy
    Tamiyacowboy Pippa's Owner
    Piaggio Skipper
    Sfera 50 early model
    sfera 50 RST
    Sfera 80
    sfera 125
    Sfera 50 dell'orto carb (PHVA 12)
    pilot screw settings (turns out)
    with 0.8mm thread pitch = 2 to 2 1/4 turns out
    with 0.5mm thread pitch = 3 1/2 to 4 turns out
    fuel level = 5mm not adjustable
    starter jet 50
    pilot jet 34
    main jet 56
    Needle (clip setting) SA2 (third notch down from top)
    Sfera 50 RST dell'orto carb (PHVA 12)
    pilot screw setting not available
    fuel level 5mm not adjustable
    starter jet 60
    pilot jet 36
    main jet 70
    Needle clip setting A12 (2nd notch down from top)
    sfera 50 RST weber carb ( weber 12 OM )
    Pilot screw setting not available
    fuel level 3.5mm not adjustable
    starter jet 50
    pilot jet 34
    main jet 78
    Needle clip setting F (3rd notch down from top )
    sfera 80 dell'orto PHVA 17.5
    starter jet 50
    pilot jet 34
    main jet 65
    Needle clip setting A7 ( 3rd notch down from top )
    sfera 125 mikuni BS24-1J
    float hight 12.2mm
    starter jet 40
    pilot jet 20
    main jet 87.5
    needle clip setting 4CZ6 ( 3rd notch down from top)
  2. Tamiyacowboy
    Piaggio Skipper
    Typhoon 50 / 80 model
    Typhoon 125 model
    Typhoon 50 Dell'orto PHVA 12
    starter jet 60
    pilot jet 36
    main jet 70
    Needle setting A12 (2nd notch down from top)
    Typhoon 80 dell'orto PHVA 17.5
    pilot screw setting = 4 1/2 turns out
    starter jet 60
    pilot jet 34
    main jet 62
    needle setting A7 (4th notch down from top)
    typhoon 125 mikuni VM 20-325
    pilot screw setting = 1 3/8 turn out
    fuel level 3.5 + or - 0.5mm
    starter jet 40
    pilot jet 35
    main jet 82.5
    needle setting 3CK01 (3rd notch down from top)
  3. Tamiyacowboy
    Piaggio Skipper
    Fly 50 Cat / Liberty 50 Cat
    Fly 125 / Liberty 125 /B125
  4. Tamiyacowboy
    Piaggio Skipper
    ET2 early model
    et2 later model
  5. Tamiyacowboy
    Piaggio Skipper
    ET4 50
    ET4 125
  6. Tamiyacowboy
    Piaggio Skipper
    GT 125
    GT 200
  7. Tamiyacowboy
    Piaggio Skipper
    Hexagon
  8. Tamiyacowboy
    Piaggio Skipper
    LX2 50 Cat
    LX4 125
  9. Tamiyacowboy
    Piaggio Skipper
    NRG MC2 -MC3 - Power
  10. Tamiyacowboy
    Piaggio Skipper
    Skipper 125
    Skipper 125 ST
  11. Tamiyacowboy
    Piaggio Skipper
    X8 Parts 1 and 2
  12. Tamiyacowboy
    Piaggio Skipper
    X9 part 1 and 2
  13. Tamiyacowboy
    Piaggio Skipper
    Zip 50 4t / fly 50 4t /lx4 50 4t / liberty 50 4t
    Zip sp 50
    zip 50 1993 - 1999
    zip 50 Cat 2000 onwards
    Zip 125
  14. Mark Emerson Trentham
  15. Tamiyacowboy
    Piaggio Skipper
    only one i have at the moment , but i do have the specs on carbs for those models to, ie stock form main-pilot jet info. when i get the time i will start to transfer the data into the relavent schematics posts
  16. Tamiyacowboy
    Piaggio Skipper
    Heres the rest of the carbs, sorry i cannot put them into respectful schematics they are all muddle up but heres the rest.
    Zip and Zip early RST dell'orto PHVA 12 DD
    starter jet 60
    pilot jet 38
    main jet 70 (zip) 72 (zip rst)
    Needle setting A15 (2nd notch down from top
    Later zip RST dell'orto PHVA 12 DD
    starter jet 60
    pilot jet 35
    main jet 72
    Needle setting A29 3rd notch down from top
    Zip SP dell'orto PHV12 QD
    starter jet 50
    pilot jet 34
    main jet 75
    Needle setting SA2 3rd notch down from top
    Zip 50 and typhoon 50 dell'orto PHVA 17.5 RD
    Pilot screw setting 1 1/2 turns out
    starter jet 50
    pilot jet 32
    main jet 56 (zip) 53 (typhoon)
    Needle setting A22 1st notch down from top
    ET4 50 Liberty 50 zip 50 4T's Keihin CVK18
    fuel level not available
    starter jet 42
    pilot jet 35
    main jet 75
    Needle setting NACA not adjustable
    Zip 100 4t fly 100 4t keihin CVK 20
    Pilot screw setting 2 3/8 turns out
    starter jet 48
    pilot jet 45
    main jet 75
    Needle setting 4REEG not adjustable
    Skipper dell'orto PHVB 20.5
    Pilot screw setting 2 to 2 1/4 turns out
    fuel level 5.0 + or - 0.5mm
    starter jet 60
    pilot jet 45
    main jet 86
    Needle setting M6 2nd notch down
  17. Tamiyacowboy
    Piaggio Skipper
    Skipper Mikuni VM 20
    Pilot screw setting 1 3/8 turns out
    starter jet 50
    pilot jet 35
    main jet 82.5
    Needle setting 3CK01 3rd notch down from top
    Skipper st 125 zip 125 walbro WVF/6A
    starter jet 48
    pilot jet 34
    main jet 82
    Needle setting 52K 2nd/3rd notch down from top
    NRG MC2 dell'orto PHVA 12DD
    starter jet 60
    pilot jet 38
    main jet 66
    Needle setting A15 2nd notch down from top
    NRG MC3 DT , DD, Nrg power DT , DD, fly 50, lx2 50 lxv 50 dell'orto PHVA 17.5RD
    starter jet 50
    pilot jet 32
    main jet 53
    Needle setting A22 1st notch from top
    Zip RST , Zip sp/rs and nrg mc2 weber : weber 12 OM
    starter jet 50
    pilot jet 34
    main jet 75
    Needle setting S 3rd notch down from top
    Hexagon mikuni VM 20-315
    Pilot screw setting 1 3/8 turn out
    starter jet 40
    pilot jet 35
    main jet 82.5
    Super Hexagon walbro
    Pilot screw setting 3 turns out
    starter jet 50
    pilot jet 34
    main jet 108
    Needle setting 51c 2nd notch down from top
  18. Tamiyacowboy
    Piaggio Skipper
    Liberty 50 weber : weber 12 OM
    starter jet 50
    pilot jet 38L
    main jet 63
    Needle setting V 2nd notch down from top
    Liberty 125 walbro : walbro WVF/6B
    starter jet 48
    pilot jet 33
    main jet 84
    ET2 weber : weber 12 OM
    Pilot screw setting 2 1/2 to 3 1/2 turns out
    fuel level 3.5 mm not adjustable
    starter jet 50
    pilot jet 34
    main jet 76
    fly 50 4t , Lx4 50 keihin : keihnin CVK18
    Pilot screw setting 1 3/4 turns out
    starter jet 40
    pilot jet 35
    main jet 75
    Needle setting NGBA not noted
    ET4 125 mikuni : mikuni BS24-J
    fuel level 12.2mm
    starter jet 35
    pilot jet 20
    main jet 87.5
    Needle setting 4CZ6 2nd notch down from top
    fly 125, LX4 125 liberty 125 upto 2007 Keihin : keihin CVEK 26
    Pilot screw setting 1 3/4 turn out
    starter jet 42
    pilot jet 35
    main jet 82
    Needle setting NELA not noted
    LX4 124 euro3 LXV125 keihin: CVEK 26
    Pilot screw setting 2 1/2 ( 2 on lvx) turns out
    starter jet 35
    pilot jet 42
    main jet 82
    Needle setting NJHA ( NELA on lvx ) not noted
  19. Tamiyacowboy
    Piaggio Skipper
    Liberty 125 2008 onwards Keihin : CVEK 27
    Pilot screw setting 2 1/2 turns out
    starter jet 42
    pilot jet 42
    main jet 82
    Needle setting NJHA not adjustable
    X8 125 and GT125 walbro : walbro WVF/7R
    Pilot screw setting 2 7/8th turns out
    starter jet 48
    pilot jet 38
    main jet 103
    Needle setting 653 2nd notch down
    X8 125 euro3 keihin : CKV 30
    fuel level not avaialble
    starter jet 42
    pilot jet 38
    main jet 105
    Needle setting 305D not noted
    X9 walbro : WVF/7C
    starter jet 50
    pilot jet 36
    main jet 110
    Needle setting 51C 2nd notch down from top
    X9 euro3 keihin : CVK 30
    Pilot screw setting 2 turns out
    starter jet 42
    pilot jet 35
    main jet 105
    Needle setting NDYA not adjustable
    B125 walbro : WVF/7G
    Pilot screw setting 2 5/8th turns out
    starter jet 50
    pilot jet 36
    main jet 108
    GT 125 , GTV 125 , B125 keihin : CVEK 30
    starter jet 42
    pilot jet 38 ( 35 on B125)
    main jet 98 ( 105 on B125)
    Needle setting NVDA ( 304D on B25) not noted
  20. Tamiyacowboy
    Piaggio Skipper
    GTS125 Keihin : CVEK 30
    pilot screw setting 1 turn out
    starter jet 42
    pilot jet 38
    main jet 108
    needle setting NDYB Not noted
    GT200 Keihin : CVEK 30
    pilot screw setting 2 1/4 turns out
    starter jet 42
    pilot jet 38
    main jet 92
    needle setting NDAA
    GT200 Walbro : walbro WVF/7P
    pilot screw setting 2 turns out
    starter jet 45
    pilot jet 36
    main jet 95
    needle setting 459 2nd notch down from top
