NRG Power DD 2005 Birthday Project
Discussion in 'Scooter Projects' started by Subw00fer, Aug 4, 2013.
  1. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    Picture heavy thread!:)
    Hi guys, first post!
    Today i got my Piaggio NRG Power DD 2005. It cost me £350 and looks like it's going to fail MOT tbh.
    _____________________________________________
    Plans(of 27/09/2013-Present):
    Performance:
    Stage 6 Streetrace 70cc
    Malossi RHQ Crankshaft
    Malossi Red Sponge Insert + Removed Airbox Snorkel
    Stage 6 Pro Replica
    Heavy Duty Crankshaft Bearings And Seals
    Motoforce Evolution Sports/Race Clutch
    Racing Reed Valve Block
    Malossi Multivar
    Malossi X Special Belt
    De-Restricted Inlet Manifold
    Stage6 Medium Torque Spring
    Stage6 107mm Clutch bell
    Visuals:
    Stage6 Adjustable Jack Up Riser Kit - Carbon
    Side Stand + Remove Centre Stand
    Matte Black Respray
    Custom Rear Indicators (were already on bike)
    6x4 Numberplate
    Carbon Look Brake Levers
    Xenon H8 Headlight Bulbs
    Fly Eye Tinted Headlights
    NRG MC3 Wheels Powdercoated White
    Need:
    New Brake Light Switch
    Exhaust Studs, Bolts and Gasket
    New Horn
    New Spark Plug
    New Engine Case
    New Inlet/Reed Gaskets
    New Water Pump Kit
    New Oil Pump Belt
    New Rear Wheel Bolts
    New Kickstart Case and kickstart
    New Battery
    Standard Rear Light
    New Rear Tyre
    Green = Purchased
    = Done
    ______________________________________________
    Needs a damn good clean tomorrow.
    few things i'm concered about;
    (Pretty sure this is the rollers); It doesnt move until the revs are all the way up to 5k, and when riding, the only power that feels right is inbetween 5-7k rpm. I think it then struggles to go over 7k... so help/what weight rollers would be appricated.
    Also, the indicators are so dark! Is that standard for NRG's? They just look so dull.. not sure really. lol noob
    Another thing is, the underseat panel; I have it, it just doesnt seem to fit on properly... i should really buy a haynes manual, but for now i'm trusting you guys! lol nooob
    And finally, the electric start doesnt work, no idea why, just seems way too weak, what should i replace for that?
  2. supraking
    supraking Well-Known Member
    Honda MSX125
    welcoem along, nice ped matey :) (ive got a dt in that colour)
    front indicators are standard, rears have been swapped
    as for your problems, tbh they sound exactly like how mine runs :) ive just never thought it was a problem
  3. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    strange, it doesnt seem right.. Anyway, i've ordered some 4.5g rollers and a mirror, because for some reason, mine came with no mirrorso_O
    Also my horn is so weak, it's so pathetic and just makes you crack up
  4. supraking
    Honda MSX125
    lol, you should hear my hongdou horn lol :)
    it may well be wrong but i wouldnt know either way, it seems to run well enough for me. just wish my speedo worked properly
  5. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    what's up with your speedo?
    well, i filled the tank this morning and after that i began stripping it all down to clean it, as it looked like someone had literally driven it into a 10f mud puddle...
    [​IMG][​IMG]
    all back together again
    So after it was all back together again, i went out for a quick ride and it instantly felt better, i managed to get it up to 34mph before i ran out of space, (only had about 100m). It's fast! and there's nothing wrong with it, all it needed was fuel i'm guessing!
    some pictures;
  6. supraking
    Honda MSX125
    looks great mate, fuel always helps :)
    my speedo sometimes will read correctly but most of the time it flicks from 0-what ever im doing, and anywhere in between.
    not sure if its the sender, the cables, or the dash but somethigns not right with it :)
  7. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    hmmm strange, i dont have a clue what it could be :D
    but yeah, needs abit more work, the exhaust needs painting, there's a few cracks here and there and lots of scratches, also there are loads of screws and bolts missing
  8. supraking
    Honda MSX125
    i jsut dont know how people can abuse them that much, does my head in loosing screws and getting dings/scratches
  9. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    Mine and my friends Sym Jet 4 (mine's faster ;))
    more coming tomorrow
  10. polinipete
    polinipete Member
    nice scoot mate i ave the same one at mo totally in bits my second project :eek: if it turns out as good as my first one il be a happy chappy :) bet it leaves the sym jet behind lol ?
  11. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    haha nice, yeah it does but i'm not sure how much it will rape it by yet cause i havent got my licence!
    anyway, this happened today (more cleaning)
    first picture, such a big difference
    and this...
    the fuel level looked like that, and was flashing, even though my tank is pretty much full... after this i fillied it to the brim which didnt take a lot as it was already nearly full, and it was still displaying like above, so i rode it and about 10 seconds later it was back to normal again, really strange
  12. Stevep
    Yeah nice scoot, and welcome to the forums.
    For the fuel sender problem - check for corrosion on the plug connectors at the fuel sender unit; when they are nice and clean check the terminal connector at the back of the clocks. More than likely got some corrosion on the brass pins. Take care cleaning them up, use some wet and dry paper and an ice lolly stick or thin diamond file. Might be worth going over the horn connectors as well.
    Glad you bought a mirror for it, it is an MOT FAIL without mirrors. You have to have at least one on the right hand side. Dark indicators are not a problem as long as they show yellow light when in use. Make sure that rear light does not flash when holding the brake levers in. If it does then you will need to replace the brake light switches at the handlebars. Also check the way it has been wired. I've had plenty of these where the wires have just been twisted together, and you wont know that it aint working until someone in a blue uniform tells you!
    Apart from that, re-paint it tango orange, satin black, and gloss black wheels. Look mint.
  13. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    Thanks for that, very helpful! i didnt actually know the mirror had to be on the right, the one i ordered says it's a left hand but the picture clearly shows a right one...
    Once i have the money i will begin painting it, not sure about tango orange though:p Also i'll buy a performance variator. If i get any more strange occurrences with the fuel gauge i'll do what you said, cheers
  14. Mark Emerson Trentham
    Hongdo owner with optimism?,
    There's hope for the chinese m/c industry yet. :D .
    supraking likes this.
  15. Mark Emerson Trentham
    Wish you best of luck on your project. :) .
    Subw00fer likes this.
  16. supraking
    Honda MSX125
    Haha. I do my best. Actually beginning to like the hongdou. Cant wait to get it on the road. Its been an exciting journey figuring out its quirks.
    and subwoofer. Orange stickers matey :)
  17. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    thanks!
    we'll see;)
  18. Mark Emerson Trentham
    ^ projects like this are a joy to watch come together,
    yours is well cool!,
    but Mr.Rox's is the bomb!!. :D .
  19. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    i need to clean my tyres! but i don't have and tyre cleaner, reckon there's anything that could do it which i could find in the kitchen cupboard? :D
  20. Mark Emerson Trentham
    Watch thread engaged!. :) .
