ok guys so i bought this runner for £1200 all numbers are matching and the hpi is clear it has a pm 59 with red end can malossi 172 kit malossi reed block and reeds malossi intake 25mm dellorto with manual choke some open airfilter malossi shock vx forks pm levers pm tuning back wavy disk and evos ok now the bad bits this is where im gona need your help first i dont think the fan is working , the temperature gauge not working, the indicator switch is worn out and loose i think the indicator relay is gone as indicators stay on when i turn them on the brake light dont work the ignition barel is not working ( strts with no key as the thing at the back is missing ) seat lock dosent work ( not snaped or broken just no key barrel ) the high beam is not turning on ( maybe not wired up properly?) and back tyre is gone ok so plans for the winter : manual switch for fan new buttons koso speedo new relay front led indicators lexus back light new ignition barrels so same key for seat and ignition new seatlock wire the evo light up properly brand new set of tyres set of brake pads engine cleaned and sprayed black grab rail sprayed in black pm pipe cleaned and painted all new same bolts for plastics some alarm system flick up number plate a nice kick star lever wheels powder coated in neon green same as the spare set of evo vents that i have malossi shock spring sprayed in black some new foot pegs and foot plates im keeping the aerox till i turn 17 ( april 2012) . For my runner got a complete wiring loom for £40 yesterday and a pair of indicators so i think the new loom will sort out some problems, i have also stripped it down completely and it looks like the engine has newer been token out yet so will do a good clean up , spray the frame and forks maybe the engine for now will come up with some pictures . here are some that i have done few days ago : here is some pictures got new piston rings in , spayed the frame and forks in black everything else is cleaned etc etc some pictures soon Freshly sprayed frame J I know you lot going to judge me because I sprayed the disc but I have cleaned the paint off now engine and matt black forks in I haven’t took no more pictures as it was dark but bike is on the wheels and runs had a little go on the street , Wheels are going to be powder coated in gloss black as soon as I get my new tires , Still have a lot of work to do. my budget disappeared so need to wait for xmas to get some fresh parts so things that i want to do : new foot plates spray inters in matt black spray wheels in gloss black spray grab rail in black spray the gold bracket in black get some different end can get lexus style tail light ant tint it a little bit led front indicators also slight tint koso clocks new set of pirreli tires new brake pads front wavy disk carbon under tray small numberplate carbon mudguard, pass mot buy some taxes and finally some get massive chain and loud alarm a little accident: since last time i have fitted malossi belt, malossi torque spring, new torque drive and new front pulley.i was disappointed about the horn as you could barely hear it because of the engine is so loud so i now have fitted two piaggio horns and that shit sounds like a lorry now , also have fitted smoked lenses all round in addition to that i have done some work over weekend - wheels, side case and grab rail sprayed in gloss black.oh and i got few orange led's in my speedo instead of little bulbs that dont give no light at all ,here is some pictures:final product : thats it for now , i still have some things in mind but thats if i get a job as this little toy is to expensive for a 17 yr old that goes to college
Hey, i have a 2001 runner and my temperature gauge doesn't work either neither thee fuel gauge. Im gonna be looking into these tomorrow so whatever i find out ill let you know
im keeping the aerox till i turn 17 ( april 2012) . For my runner got a complete wiring loom for £40 yesterday and a pair of indicators so i think the new loom will sort out some problems, i have also stripped it down completely and it looks like the engine has newer been token out yet so will do a good clean up , spray the frame and forks maybe the engine for now will come up with some pictures sooooooon , here are some that i have done few days ago : Uploaded with ImageShack.us
I always like the look of painted forks on runners. That's deffo the best aftermarket headlights to put on a runner as well. More pics more pics!
thanks , i will put some pictures up tomorrow and yh i came up with idea of making it sort of ghost bike so i want to get rid of any other color that is not black
Freshly sprayed frame J I know you lot going to judge me because I sprayed the disc but I have cleaned the paint off now engine and matt black forks in Shot at 2011-11-27 I haven’t took no more pictures as it was dark but bike is on the wheels and runs had a little go on the street , Wheels are going to be powder coated in gloss black as soon as I get my new tires , any one know which ones I should get??? Still have a lot of work to do so will have some updates soon J
ok so the 'winter' project is nearly done and its 1st of december , still have loads of work to do but my budget disappeared so need to wait for xmas to get some fresh parts so things that i want to do : new foot plates spray inters in matt black spray wheels in gloss black spray grab rail in black spray the gold bracket in black get some different end can get lexus style tail light ant tint it a little bit led front indicators also slight tint koso clocks new set of pirreli tires new brake pads front wavy disk carbon under tray small numberplate carbon mudguard, pass mot buy some taxes and finally some get massive chain and loud alarm
little update : sorted out the evo light now the high beam works , also the horn is working all trough you cant hear it when engine is running . but there is a slight problem all my electrics start working only when i start the bike ?? i dont really mind that but will i pas MOT like this?? if no what the problem could be? i think i connected the startor wrong as i dont work :/ could that be it?
lol im keeping it till spring when prices are going up then i think im gona sell it as there is no point keeping it i will rather invest the money in my full bike license
