first of all, Hi, thought i was a member on here already but i guess not, so here i am some of you may know me from uksf/uksr, gilerarunner.net, im benny, from doncaster heres my project. spec : ported stage6 racing cylinder (by Darrell Taylor) flowed cases & matched to cylinder, opened out to match feeds on barrel Yasuni C16 (may chance to C21 at a later date) motoforce evolution crankshaft stage6 main bearings and seals 25mm carb Malossi MHR multivar Variator RamAir air filter stage6 v-force3 reed block stage6r/t straight inlet metrakit clutch malossi clutch bell stage6 primary gear up kit stage6 CNC racing drive Stage6 Kevlar drive belt NGK red HT lead and spark plug cap Leonelli race ignition my wardrobe is now my parts shelf
some pictures after i got my cases and cylinder back from Darrell Taylor of 50cc tuning. a picture paints a thousand words :wub: :wub:
just waiting for a water pump kit, then im going to start building it up, so should be built and ready to slot back into my bike by end of next week at the absolute latest.
couple more pics.... my top racing clutch, similar to the stage6 clutch, with the allen key adjustment... athena platinum belt ( same as stage6 kevlar) engine nearly built, waiting on engine mounts and gasket set my bar converison. well, been at it all day and done a lot of work on my panels, not 100% finished yet though, they all need laquering as their flat as f*ck, bike needs a gud clean, need to put on my belly pan and foot plates etc, put indicators on,etc. etc. etc. loads more work yet. few pics...
