http://s214.photobucket.com/albums/cc165/Axton1/ I have done so much to this scoot. I have a Corsa/r and a Polini Evo now with a Kundo crank, 19mm arreche, O/R tranny, Aerox cases, 13'' rims, and a crapload of other stuff. I paid $1,200 for the bike and put over $3,000 in parts on it. It tops out at 65 mph with the Ported Corsa/r. This winter I am putting the Evo on and a 28mm PWK carb after I convert to LC.
technigas exhausts are nowhere near good enough to perform well on a corsa kit. would be much better off with a city16, you can choose what end can as well.
I have the following mods on my bike; Polini Corsa/R Malossi Crank Malossi O/R tranny Polini speedbell and 2G CF reeds 28mm PWK carb Aerox cases Bitubo shock with 2'' riser Green ground FX lights 13''Aerox rims Brembo brakes Custom paint Greenwood front Flush mount blinkers Avon Viperstrike tires Technigas None And lost more!
Here is the carb I am going to get. http://www.scooterwest.com/item_detail/ ... mm-carb/9/ How do you think it will compare to the 28mm PWK that I have?
am wiv you all the way m8 a carb that size is stupid considerin you could buy a hebo pipe or a zx for that price m8 get a proppa pipe kid i only have a 25 mm carb n iv got a highly tuned 183cc bike nibbles
with your setup a c16 would be perfect, hebo revolutions are good but a yasuni would be sooo much better with you setup
