Could someone please tell me weather a front fork from an old shape zip sp be the same as the new shape? Thanks :mrgreen:
Thanks. To remove them do you just take off the nuts off from just under the handlebars then slide the fork downwards?
Handle bar plastics off, unclip cables that will hinder pulling the bars upwards. Undo the top nut on the stem, wind it out a fair way then tap down with a rubber mallet to release the clamp. Using a rubber mallet tap the bars upwards so they are free from the fork. Remove the brake line, speedo cable? (I dont have one on the racer) Knock the lock ring off the top of the fork stem then undo the race with your hand, support the forks as they will drop!
