Hi, I have a quick question.Am derestricting a 2005 Piaggio Zip SP. Variator is already done-increased speed from 29mph to between 35-40mph depending on wind! Next job is exhaust. I will remove the two blind pipes and plate over the hole. Then take off the hose for the SAI system where it joins the exhaust and plug that. I am NOT removing the brass plate at the carb entrance. What size of main jet will be required once the exhaust is derestricted? thanks
had my standard exhaust derestricted when i bought it new as far as i know thay never upjetted it, dont wast ur time tho just get a after market pipe, leo vince are good for the price
you can fit a leo vince on a 50 and will work well when you upgrade to a sport 70 i only had mine two weeks before i fitted a pipe she wassent even run in lol
mines still running standard de restricted exhaust and i am more than happy with the difference in performance it made de restricting certainly its alot faster than friends aircooled zip with 5 gram rollers expansion pipe fitted
