zip rear wheel fit on jog rr engine block
Discussion in 'The Workshop' started by smarty_boi, Sep 23, 2007.
  1. smarty_boi
    smarty_boi New Member
    hi there i have a jog rr engine which i am putting in a pit bike frame need a skinny 10inch rear wheel what i can fit a motocross tyre on to fit the yamaha jog rr engine block, need a wheel to use where i can still use the rear drum break. cheeres any help appreciated
  2. kyle1b1
    ice have 10' wheels and have rear drum and i think the typh have.
  3. smarty_boi
    so do u think it will fit on the yamaha jog wheel shaft also what is the width of the rim
  4. kyle1b1
    i dont know if it will fit and the tyre width that go on are 120s
  5. smarty_boi
    do you think a honda vision wheel would fit on a yamaha jog rr engine block
    the wheel size needs to be 2.75" x 10"
    does any 1 know a wheel which is 2.75" x 10" that would fit a yamaha jog rr
  6. binge
    binge New Member
    Why don't you just get a knobbly 12" tyre?
  7. smarty_boi
    cos i cart find i knobly tyre which is wide enough to fit a 4 an 3/4 inch wide wheel
    think i might get a aerox engine block and bolt a yamaha pee wee wheel to the disc/wheel hub
