zip bearing problems
Discussion in 'The Workshop' started by burtie zip, Nov 16, 2007.
  1. burtie zip
    burtie zip New Member
    Right the bearing on the variator casing that the shaft from clutch sits in has seized on the shaft and left the outer part in the casing any ideas how to get it out ?
    also anyone know the part numbers need them urgently please :nerd:
  2. MiNoR cOnFuSiOn
    ether a bearing puller or set a heatgun on the outside of the case with it facing up, (suitting flat on the floor) give it 20 mins an it should just drop out.
