Piaggio zip 10 plate Stage 6 mkII 2 70 kit Stage 6 pro rep exhaust Stage 6 clutch Standered air box 72 main jet Can anyone suggest some other parts I can purchase to increase acceleration and/or top end speed ?
Gear up kit , but your gonna need someone to fit it for you. will increase your top end speed but you will lack a little bt on lower end due to the higher ratio your adding to the rear primary and secondary gearing . To be frank and honnest 16yr old will have the book thrown at them if found to be riding not in accordance to licence , so i would just hold off the gear up kit until you touch 17yr old then throw in a gear up kit and have like 60-70mph , even then your gonna have to take good care of the motor and keep ontop of it .
