replaced the regulator/rectifier thingy under the left hand side panel and still no luck. They did flash for a bit but when i flicked the switch again they stopped. :huh: anyone got any ideas?
Eliminate the rectifier flasher from the system. Buy a flasher relay (couple of quid) two pole 12v. Take the handlebar cowling off to reveal the flasher switch on the handlebars. Run a wire from the power to the horn to the "B" mark on the new flasher relay or find a live with ignition on and do the same. Cut the black and blue wire a few inches from the flasher switch on the bars and run this to the "L" terminal on the flasher relay. You now have indicators when the ignition is on :grin: Power is supplied by the battery with the ignition on....runs to the relay which is dormant until you use the flasher switch then diverts to which ever side you`ve flicked the switch.
