zip 50 carb keeps squirting out petroel and leaking - help
Discussion in 'The Workshop' started by typh-gilly99, Oct 27, 2009.
  1. typh-gilly99
    typh-gilly99 Member
    Typhoon 125 2T
    turn on the bike and theres a leak, when i throttle it starts to squirt and leak. Looks like its coming from the bit where the air box meets the carb. I have checked the carb, jets, throttle cable and even changed to a different carb and the leak is still there.
    what could it be?
  2. crotch_rocket
    crotch_rocket New Member
    Zip 50
    i had the same issue but i changed the carb to another standard one and it worked but i think im still having a few very minor problems id suggest maybe the fuel tap or fuel lines...
  3. MiNoR cOnFuSiOn
    yup, fuel tap obviously fucked and it sounds like youve put the float in wrong twice...
  4. antos
    antos New Member
    same thing happend to me !And it was a fuel tap prob it was spittin every 2 km and would die after that and then thousand kicks till it runs again....
