I got a 50cc zip 2t, what mods can i do to it to go fast without changing the fact its a 50cc. Give me some parts and REAL speeds i should be getting. Also it has to be quite cheap.
New exhaust, probably a Leo Vince, don't go for a Yasuni or anything like that for a 50cc, upjet, maybe change the variator? none of this is cheap though tbh, you should just look into it.
Put on a sports exhaust and you will notice a huge difference. Make sure you de-restrict the new exhaust. And if you Zip isn't de-restricted at the moment then this will need doing too. I'd say just get a ZX exhaust, you MUST stick the rollers in and the clutch springs if you're feeling brave but not a necessity. You would need to up jet by a few sizes too.
Some people don't have a clue ? Why don't you want a 70cc kit ? If it's being 16 and worried about getting caught with a 70's ? After you de-restrict you're breaking the law anyway. You can buy the stage 6 street race which has 49cc stamped on it. You will gain more speed/acceleration from just bolting a kit on than buying anything else at all/ If you're that adiment about not geting a 70's Best Idea get a yasuni z if you're staying a 50. If not get a yasuni r, Will be a little worse on a 50 but will work much better performance, So if you're staying a 50, Get a yasuni z/polini variator kit,comes with a new belt/ check your clutch isn't warn out. How many miles has your bike done ?
take off old piston, put new one on. put the rings in correct position slide barrel on bolt it up, change the jet you're done.
