YSN Carb help
Discussion in 'The Workshop' started by AeroxJoe, Dec 16, 2009.
  1. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Right, i fitted my new YSN 17.5 mm carb today, onto my aerox from donotlink pedstop
    right, first the bike would race, cos the the throttle cable was stuck :(
    Right thats not the problem, that one is fixed :)
    when i went to drive my ped home, i gave the bike full throttle , worked for a like a metre or 2, and then start bogging :(
    Description from donotlink
    Characteristics
    Manifold Union : 24mm
    Filter Union : 35mm
    Main Jet : Dellorto 6mm type - size 90
    Pilot Jet : Kehin type - size 34
    Manual Choke : Standard
    Oil connection : Standard autolube
    Vacuum connection : Standard
    Fuel connection : Standard
    Water/ Heater pipes : Standard for LC models, disregard on AC models
    Right, the main Jet hasnt been touched, the pilot jet was swapped for a 36 from my 12mm standard carb, and it ran well, but with the 36, it still runs poor :(
    Any help please,
    and can someone point me in the direction of where i can find a Kehin Pilot Jet
    Thanks
    Joe
    donotlink peddy : http://www.donotlink-pedstop.co.uk/p/175MM-SPORTS-CARBURETTOR-FOR-M-2563.aspx
  2. adz452
    adz452 Member
    Vespa T5
    main jet is prob to big rollers prob need ajusting for the new carb to?
  3. capri dave
    capri dave Active Member
    just sounds like a classic case of the carb needs setting up ;)
    as for the pilot jets, donotlink sold you the carb...would be a bit lame if they didnt stock the jets for it :glare:
  4. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Capri Dave , how do i set it up ?
    im more of a moped noob, and dont know much about setting them up :banghead:
    Cheers for the advice.
