Yasuni Z to C16
Discussion in 'The Workshop' started by Gilly-93, Jul 9, 2010.
  1. Gilly-93
    Gilly-93 Member
    Aprilia Sr70
    Before you all say search the forum i have done and had no luck lol. So here go's... Going to get a C16 tomorrow now ive got the money, and i was wondering if i will need to upjet anymore or change the rollers from using the Z to the C16? Ive had it set up on the dyno and its running perfectly, so i dont want it to get much worse. Also im running a standard carb with airbox. As soon as i get another £100 i will be getting a 21mm carb for it. Then get it done properly on the dyno again. Thanks in advance. :)
  2. capri dave
    capri dave Active Member
    when i changed my Laser x pro for a c16, i didnt upjet and one very cold winters morning i put a hole through my piston...
    The thing is i had been riding around for 2 weeks beforehand, and was very pleased with the performance...so the moral of the story is keep a regular check on your plug colour ;)
  3. Gilly-93
    Gilly-93 Member
    Aprilia Sr70
    Thanks for that mate. I ended up buying the pipe, 21mm carb and a new reedblock. Put it all on and alterd the jetting abit. Running ok, but needs to be dyno'd again to get the best from it. But its still made a hell of a increase in power :) Thanks.
