yamaha aerox overheating
Discussion in 'The Workshop' started by scootercooter, Aug 3, 2011.
  1. scootercooter
    scootercooter Member
    yamaha aerox
    the other day i was riding and noticed a puddle of what on the foot boards of my aerox.i pulled over a found that it was coming from the water reservoir above the radiator but i cant seem to find out why it is.the water pump is working because i can see the water circulating and the gasket is fine because it only 2 months old. oil pump is working fine as its still using oil.the temperature warning light hasnt come on yet either
    please help
  2. jet
    jet New Member
    all you can realy do is look. if you know where its leaking from check loose pipes, cracks, splits..... and then obviously replace whats broken. or you could have over filled it with water?
  3. scootercooter
    yamaha aerox
    its leaking from the cap so im gunna buy a new 1 and hopefully that will fix it
