I got a yamaha aerox with polini 70s The other day my gaskets went so I went and bought new ones, fitted it And now my ped just wasn't starting Could anyone help?
Hi Which gaskets? Do you have a spark ? is everything connected (carb- wise) properly? Sometimes after a rebuild they can be a bit reluctant to start. but check the stoopid stuff first.
Thanks for that it was fine after a while carb needed cleaning out and stuff do you know what the problem could be if all petrol Is coming out of over flow
That means the needle valve is not closing. This can be caused by: crap in the needle valve seat worn needle valve cone floats that don't float (holes in). Usually the first- but you never know until you look. Good luck.
Alright thanks so it's something to do with carb I'm putting it in garage today so il get back to you
