wont start when cold splash some fuel in the carb and away she goes and starts while hot .. once it goes cold again wont start the carb is clean and clear had always beenn a good starter before , cold it be reeds they are not seating right on one side of the block any help ?? please
Have you got a pipe coming out the back of the engine case? Just infront if the rear wheel. Mine had the hose blanked off because of my sports pipe, but it split making a huge air leak
I have to wet the plug with fuel to get it to fire... when it finally fires, you can start it all day... only when you leave it for 6 or more hours... it wont start
Could be choke, or the reeds may not have the correct clearance or may not be working properly. I had a similar problem in the past, turned out to be the reeds.
I have never run a choke. I live in Queensland Australia, and it never really gets cold enough to use a choke. But in saying that, I have a 19mm carb with a cable choke. I did try it and still nothing happened. I am having to inject fuel into the carb by hand to get it to fire up
