Hey everyonee im having trouble getting my new polini kit, i stripped my whole engine down, and replaced everything what i got with my kit, and im having problems on where my 2 stroke pipe goes stupid i know, but i forgot where it came from. so if anyone has a engine diagram, so i can see where it goes. Not finished.... my engine dont start ? it starts, ticks over, CONKS OUT !!!!!!! help please. i can show you a video of what happens.
oil pipe goes from tank 2 pump pump to carb the little brass nipple on the carb cant miss it and watever u do dont run ur bike without oil or your kit will break
but it starts when fuel is pumped into the carb. my mates got an aerox 05, his oil pump pipe goes into a slot near the water pump. if it starts , ill tell ya.
of course your bike will start without oil it will just overheat and seize... you can fit a 70 kit but dno how where your oil came from?
Normally the oil pump will be by the magneto, one thinish pipe going to ur carb.. and the main pipe from oil tank to the oil pump.. remember to bleed it.. undo the screw untill oil comes out.. (Will be obvious when u see it)
oil pump is when you take kickstart case off if you look head on its a lil brass thing at botom left just nxt 2 variator thers a belt running from crankshaft 2 it so you cant miss it
