Yamaha Aerox Bogging
Discussion in 'The Workshop' started by AeroxJoe, Feb 11, 2010.
  1. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    This is for my mate, not me
    i know there is loads of posts which are the same about this,
    my mates setup
    Athena 70cc bore
    moto force crank
    3.6gr rollers
    21mm carb
    technigas R sport exhaust
    hes having problems with it
    when he accelerates, the bike bogs at a certain speed
    he said approx 30-40mph, he dont know if this is due to Jetting, rollers or whatever
    hes checking his jets today, and then i shall EDIT this, if its due to jetting, should he down jet or up jet ?
    Thanks for your help
    Joe
  2. DUNKMAN
    DUNKMAN Member
    yamaha neos 50
    no leaks in air box or anying ,clean carb??
  3. mutant707
    mutant707 New Member
    YAMI AEROX
    IS the exhuast 70cc compatible? Some race pipes dont work very well with upgraded cc kits
  4. gregzzz
    gregzzz New Member
    nrg
    nonsense, my mate was running a evo2 aerox with a tt.
    what colours your spark plug? get a pic up
  5. MiNoR cOnFuSiOn
    drop the roller weight slightly
    next person that says "check what colour your plug is" whena bike "boggs" will be banned.... most useless peice of advice out there
    its rollers, always is rollers, always will be rollers wiht these, you can run them rich/lean as FUCK without it bogging, TRANSMISSION stall is what people usually refer to as bogging, an auto can only "bog" if the transmission puts more load on the engine than it can produce (basicly its like changing gear too quick in a car....) fuck all to do wiht jetting
  6. mutant707
    YAMI AEROX
    Some race cans dont work very well with bigger bore kits, Something to do with sizes of the exhuast etc.. Alot of race cans are designed To give a big compression boost for the 50cc engine and not a 70cc upgrade. The type of exhuast you have can make the world of differance with the power bands and response etc. I know this as its something i have come across in the past and it was resolved by changing to a more sutible pipe!
