Hi all, I have a Yamaha aerox with a stage 6 exhaust, 80main jet and recently just fitted a polini variator, polini belt and 6.9g roller but not yet put the spring in the clutch as don't have the socket set at the moment. Before I put the variator in it was a fast ped went about 50-55mph, now it takes ages for it to kicking and don't accelerate it takes ages going from 0-35mph and no faster need help thanks
6.9 gram rollers a bit heavy , what rollers did you have installed before the variator upgrade around 5g ? if so pop them in and you will see that low end pep come back. its those near on 7g rollers thats holding back the power. see your pipe makes its power fairly high on rpm and your heavy rollers are not allowing the engine to be around that peak area when your pulling away so your not harnessing the powerband spread the exhaust gives you and that means your pull away speed is suffering, then when you get to 35mph the pipes power cuts in and your speed increases , BUT if your rollers are to heavy the variator could have already reached its max and wont open any more so your belts not riding up so high as it used to. when you get the chance get that rear contrast spring fitted to that will help on the low to high ratio change when your on and off the throttle
Alright thanks I will be put the spring in on Tuesday and what rollers do u suggest as I had standard rollers in before
Hi do I put the rollers in as they are now or do I put the shells on on the right side as there are rollers already inside I think ?
shells on, then pop them into variator. the shells are protection for the rollers the outer shell is harder and takes all the wear and tear
There's a left and right to the rollers btw! so the metal innards do not fly out when's it's spinning round!
