Yamaha Aerox 50cc (80cc) 2000 - head light bulb, weight rollers, Exhaust questions
Discussion in 'The Workshop' started by Peter Lindberg, Sep 3, 2020.
  1. Peter Lindberg
    Peter Lindberg New Member
    Hi guys.
    New guy here, and new to scooters.
    I have not had a moped (50cc) since early 80s and they did not look anything at all like they do today. Everything is way more complicated and "electronic" today. :)
    Anyway. I got me one of these scooter mopeds 2 days ago to have for shorter trips etc now during Covid19 restrictions.
    I work from home and the car i have not used for months, so this will be a new little toy for me.
    I will paste the specs of my bike below. But right now.
    headlight is dead, bulb dead. So while im getting a new, i want to ask, what is the best, strongest "road legal" light bulbs that can be used. as for the car i have replaced Halogen with LED. much better result in dark driving.
    So just want to know what you guys have been using. I think its a BA20D 35/35 as standard, and thats probably just slightly better than a flashlight from the pound store.
    I will also have to change the weight rollers as they are getting old. Just not sure what weight to go with here. I rather go for more torque from the get go instead of a bit higher top speed. right now it wont start move until its on quite high RPM (ive no RPM meter so cant say exact) i would rather it start to move on a lower RPM if possible. Would anyone be able to advise on what weight is most suitable?
    And finally. Too Loud EXHAUST - previous owner have added some upgrades as i will list below, specs from the add where he sold it. Anyway, its a very loud exhaust now, as i think due to get maximum effect out of everything. But i feel its too loud and sharp (as 2 strokes usually gets) its quite uncomfortable to listen to for too long time. if i were to put on a more muffled exhaust to get noise down a bit. how much effect would i lose? can anyone advise of an exhaust that would suit my needs?
    Anyway, a long first post from an old guy who forgot how fun it can be with mopeds and scooters. All input will be greatly appreciated. Thank you//Peter
    Specs
    • Yamaha aerox 2000 70 cc stage 6 cylinder (NOT 80 AS HEADLINE SAYS)
    • Basically everything is new installed last summer almost all parts are almost 1 year old.
    • New stage 6 chrome exhaust has a little dent from over turning
    • Malossi racing variator
    • Brand new kevlar racing belt malossi
    • Racing clutch with black spring
    • New oil in transmission gears
    • All starter components replaced and are new, ( motor, gears, flywheel etc..)
    • New water pump
    • Oil pump and tank removed self mix is necessary this is due to the engine being 80cc and needs little bit more oil than original 49cc
    • New magneto coil
    • Racing CDI
    • New spark plug
    • Temp sensor shown on digital display
    • Stage 6 street race cast iron 80cc cylinder head and piston
    • Stage 6 replica exhaust
    • Racing shaft bearing
    • Rear disk pads new
    • Front disk pads are old but 80% so they were not changed but i have them in the pack new
    • I think 19.5 dellrotto carb ? Or 17?? Need to double check
    • New air filter box and malossi filter
    • Also comes with jets thin 80 to 100 .
    • Alarm disk lock with 2 keys
    • Chain lock with 2 keys
